Sorting out drill motors
This topic is closed.
  • Sorting out drill motors
    hi all
    i will need to put some screws into my drill motors in order for them to work properly, i know the procedure but just wanted to check the postioning (black dot), i have attached a link so if someone could tell if im on the right lines
    http://www.psychoflingteam.co.ukwww.psychoflingteam.co.uk then robot improvements
    thanks alex
    Whats that for? To stop the clutch from slipping?
    I wouldnt take such a destructive approach to it, just get a short bolt (m5 i think) and just screw it into the holes in the front where the metal balls used to be. Theres notches in the torque ring inside, you want the end of the bolt to go into one of these notches and screw in the bolt untill it just about touches the ring, then undo by a quarter of a turn to make sure that your not squashing it.
      http://cpc.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=FN00233http://cpc.farnell.com/jsp/endecaSea...sp?SKU=FN00233
      Just ordered some of them myself to lock-up my drills - theyve got an allen key head, and as Grant said, they just go into the holes where the ball bearings were (youll probably need to tap an M5 thread in it first so the screw doesnt meet too much resistance when going in). The screws in the above link are short enough so that once theyre pressing on the clutch, the heads lie flush with the plastic casing. Helps a lot if youre using drill mounts that sit flat against the plastic casing
        RS have similar screws. Just search for grub screws
          http://www.robowars.org/guides/guides-drill-hacking.htmlhttp://www.robowars.org/guides/guide...l-hacking.html
            thanks guys
            so the grub screws screw into the ball bearing holes and they stay in there beacuse of the plastic sides?
            i wouldnt need to go into the metal ring with the notchs on, would i? if yes how?
            thanks alex
              the grub screws screw into the ball bearing holes YES
              i wouldnt need to go into the metal ring with the notchs on, would i? Not thru the side... NO.
              (Message edited by woody on March 30, 2007)
                so they wont fall out or anything?
                thanks alex
                  No, the thread of the grub screws interlock with the plastic casing, preventing them from falling out. Its the same principle as putting a screw into a piece of wood - you wouldnt expect a screw to just fall out of a piece of wood (unless the screwhole in the wood was bigger than the screw, in which case, what did ya think was gonna happen? ). The grub screws will have the pressure of the clutch pressing on them, but because the thread is slightly larger than the hole and is cutting into the plastic, they wont pop out when in use.
                  (Message edited by K_C_R on March 30, 2007)
                    the link put by you jamie is showing that they are out of stock will these be suitable
                    http://www.rpmechatronics.co.uk/shop/index.php?cPath=28_66http://www.rpmechatronics.co.uk/shop...hp?cPath=28_66
                    8th one down
                    alex
                      can anyone see how many sre in each packet?
                        I like this place better
                        http://modelbearings.co.uk/http://modelbearings.co.uk/
                        I have got alot of screws from that place and the guy running it is excellent
                          just ordered some off the site
                          cheers to all
                          alex
                            deleted
                              odd question - what is the length of the average drill motor from motor to gearbox without the length of the threaded shaft?
