Reciever Battery packs
This topic is closed.
  • Reciever Battery packs
    hi all
    could anyone give me some advise on buying reciever battery packs? i.e what make, chargers...
    i currently use 8 AA which can be expensive to replace
    thanks alex
    8!
    4 for a receiver pack.
    8 for a transmitter.
    Note rechargeable batts are 1.2v
    Transmitter, 9.6V
    Receiver, 4.8V
    Any R/C model shop can provide you with what you need.
    Example .... http://www.ripmax.com/7index.asp?category=060-080&ItemsPerPage=100&selectedtab=060http://www.ripmax.com/7index.asp?cat...&selectedtab=0 60
    OR ....Get rechargeable AA batteries and something like this .....http://www.ripmax.com/item.asp?itemid=P-FBC10D/4&ItemsPerPage=100&selectedtab=060&Category=060-080http://www.ripmax.com/item.asp?itemi...tegory=060-080...... you should then be able to recharge the batteries whilst they are in the transmitter or in the battery holder of the receiver.
    (Message edited by woody on March 18, 2007)
      sorry i meant for the transmitter (
      thanks woody
        Hi Alex,
        try this link, company does all sorts on rechargables. http://cgi.ebay.co.uk/AA-4-x-2700-mAh-NiMh-Rechargeable-Batteries-Vapextech_W0QQitemZ320092199608QQcategoryZ14951QQt cZphotoQQcmdZViewItemhttp://cgi.ebay.co.uk/AA-4-x-2700-mA...Vapextech_W0QQ itemZ320092199608QQcategoryZ14951QQtcZphotoQQcmdZV iewItem
          if i was to go down the way of batteries and charger through the transmitter, would i need a special charger for the batteries or the transmitter? or will any do?
          cheers alex
            Which transmitter do you have?
              i have two types
              hitec ranger 3 fm sky
              and http://www.sussex-model-centre.co.uk/shopexd.asp?id=678http://www.sussex-model-centre.co.uk/shopexd.asp?id=678
              thanks alex
                The charging socket on the Transmitter connects ONLY to the internal batteries.
                Buy one of these chargers or a similar R/C type.
                http://www.ripmax.com/item.asp?itemid=P-FBC10D/4&ItemsPerPage=100&selectedtab=060&Category=060-080http://www.ripmax.com/item.asp?itemi...selectedtab=06 0&Category=060-080
                  so to sum up,
                  If you go for the single celled rechargable battery option you will need to remove them to charge.
                  If you go for the 8 cell nicad pack then you will be able to use the jacks with the transmitters and get a futaba or similar charger.
                    I disagree Gary.
                    If theyre rechargeable single cell batteries and in the transmitter then you can simply plug the charger into the transmitter jack socket.
                      fair nuf, i have only ever used the 8cell packs
                        thanks for the help
                        alex
                          what voltage should i go for?
                          will this do the job for a reciever battery?
                          http://www.technobots.co.ukwww.technobots.co.uk
                          3700-001
                            Yes..4.8v is fine.
                              id look in argos they do rechargble batts and charger very cheap as do these small shops that sell crap buy the bulk, like a pound shop but not lol you get them in run down places like high wycombe lol.
