hi guys, thinking of starting to build a bot. Am going to use to drill motors from argos. thing i want to know is what type of speed controller will i need and will the receiver over heat if i run them at 12v?
Speed controller
Speed controller
The reciever doesnt have any troubles overheating with the speedos. Those parts are seperate.
Speedos useable are
Electronises- http://www.technobots.co.ukwww.technobots.co.uk
IBC http://robowars.org/store.htmlhttp://robowars.org/store.html
or the sidewinder. (James baker sells these)
Other options are the M-tronics or the Schulzes you can buy in the RC shops. Take care and dont go for low amp ones or the ones without a reverse.
And of course the speedos Leo has. (contact me for more info)
Speed controller
The Electonize 15A + 5V would be good yes - thats part 1500-013 isnt it? If so, I would personally pay £3 extra and go for the 15A microprosser controlled one (with 5V reciver output), part number 1500-015. Ive not used them personally but they are meant to be much better than the non-microprocessor ones. And with Electonize controllers, you would need two - one per side of your robot. The IBC and Sidewinder controllers Mario mentioned control both sides from one board but they are more expensive (although I believe their performance is much better than Electronizes but again, I havent used either)
Good luck with the bot building
Speed controller
what do you think of these?
http://cgi.ebay.co.uk/Electronize-43HVR-Speedcontrollers_W0QQitemZ150080105920QQihZ005QQca tegoryZ34063QQssPageNameZWDVWQQrdZ1QQcmdZViewItemhttp://cgi.ebay.co.uk/Electronize-43...150080105920QQ ihZ005QQcategoryZ34063QQssPageNameZWDVWQQrdZ1QQcmd ZViewItem
Speed controller
http://www.teamonslaught.fsnet.co.uk/speedcnt.htmlhttp://www.teamonslaught.fsnet.co.uk/speedcnt.html
Worth a look
