Hi people, have made a robot for my 7 year old daughter, well more a modified radio controlled car, i want to make a fibreglass shell for it but dont know where to start.
Fiberglass
Fiberglass
http://www.cfsnet.co.uk/Web_FibreglassGuide.pdfhttp://www.cfsnet.co.uk/Web_FibreglassGuide.pdf
Fiberglass
There you go ........a quick Google and ..... http://www.rebelflyingclub.com/moulds.pdfhttp://www.rebelflyingclub.com/moulds.pdf
Fiberglass
If my Knowledge and memory allow
For Casting
Create smooth template.
Creat wooden box horizontally cut in half.
Use liquid (forget name - to stop pieces sticking together)to coat template
Insert rubber mixture into bottom box
Insert template
Leave to dry
Recoat exposed template in liquid
Insert rubber mixture into top box
Lower upside down bottom box onto top
leave to dry
when all dry release the mold
Though for an RC car shell you may only need the top half!!!
For duplicationwith fibreglass
Coat the top/bottom mold interior with above liquid
Start laying out Fibreglass sheet with Epoxy resin when all points are done leave to dry
Remove fibreglass copy
Glue halves together if needed.
Though Ive never tried this, thats what I think happens in some cases. Constructive criticism please.
