Featherweight Database
  • Featherweight Database
    Hey Joe...Vertical Invertable Spinners are copyright to us!
    By the way, do you need any help in retiring P.I.M.P ?
      I would like to get my next one nearly battle ready before letting you loose on the old one (although i imagine it is going to take more than superficial scratches in preston). And yes I did copy your robot and then added what I hope will be improvements (disc rather than bar, 4WD, more powerful weapon motor) I was hoping for a cross between Vortex, Scorpion Jnr and PIMP 1, I think it has a lot to live up to :sad:
      Joe Townsend
        Geoff, you havent thought about making a website for Scorpion?
          Christian,
          A website is under construction right now. May be a couple of weeks yet. http://www.teamscorpion.co.ukwww.teamscorpion.co.uk
            Joe,
            P.I.M.P is a superb machine and regardless of what gets said on the forum in good humour, I have no intention of gratuitously damaging it or any other machine in a friendly white board. (But seriously, just watch yourself in a league or comp. fight!)
            I would love to see this new creation of yours.
            I see you are proposing a 4 wheel drive machine like P.I.M.P for this spinner...One question...How the hell are you going to do all of that in 12Kg!!?
            Geoff.
              with great difficulty , probably by ignoring all that armour stuff everyone keeps on going an about
              I know you would never cause unnecessary damage, it is the necessary damage im scared of :sad:. I just hope this time i dont have to fight you in the league.
              See you at preston
              Joe Townsend
                see he is learning from me with this no armour lark.
                  2.59 FW (with thanks to Adam Clark)
                  Type- 4wd Vertical Spinner
                  Length- arround 400mm
                  Width- around 300mm
                  Speed- unknown
                  Drive- experimenting with different setups
                  Power- same as above
                  Chassis- 10mm Polycarbonate and 10mm Ali
                  Armour - Stainles Steel
                  Weapon- Vertcial Spinning Disc
                  Status- Parts and designs atm no main chassis as off today
                    Type: flipper
                    Drive: bosch 35watts
                    Power: 2 x 7.2v 3000mah ni-mh
                    Chassis: 5mm polycarb + stainless steel
                    Armour: Stainless steel
                    Weapon: Flipper hopefully 16 bar with buffer
                    Status: in the build http://www.freewebs.com/kennyrobotwww.freewebs.com/kennyrobot under robots and KENNY new
                    thanks
                    kenny
                    teamkenny
                      Name: Micro Mute 2
                      Type: 4WD Rambot
                      Drive: 2x 12V Bosch 120W
                      Power: 24V 2.4Ah NiCad
                      Speed: 30mph
                      Speedos: 4QD NCC-70s @ 50A
                      Chassis: 16mm Square Ally Bar, 6mm Ally Plate
                      Armour: 4mm Polypro... soon to be Gr.5 Titanium
                      Weapon: Gr.5 Titanium Scoop and Spikes
                      Status: Built
                        There are some photos of the Featherweight smash up on my website, if anyone wants a look. Also a full diary of the past 3 years of building featherweights.
                        http://www.cuebruteforce.8k.comhttp://www.cuebruteforce.8k.com
                          Type: Spinner
                          Drive: Technobots wiper motors
                          Power: SLAs
                          Speed: sssslllooowww
                          Speedos: Electronize 15amp cpus
                          Chassis: Urm scaps of metal I had + lodsa rivits
                          Armour: 3mm t6 + stainless + 6mm poly
                          Weapon: Bar spinner
                          Status: Gimme 2 days and some Gaffa to finish it!
                          Reason for build: Turbulence is taking to long!
                          Regards
                          Dave moulds
                            sounds like a well engineered robot then dave
                            kenny
                              Name: Andrew Kenworthy
                              type: Roboteer
                              Wepon: Extreme sarcasm
                              Regards
                              Dave moulds
                                thanks
