Type- verticle spinner
Height- 900mm
Length- 1075mm
Width- 900mm
Speed- unknown
Drive- one gold motor @ 4:1 reduction
Power- 24V 2400mAh NiCads
Chassis- 5/8 box steel
Armour - 2mm poly
Weapon- 800mm spinning bar driven by a 12v gold @ 24v
Status- part built may be done for preston event.
not the most sensible bot I have ever tried to build and those dimensions are correct.
Having just bought the inspire DVD and Im now totally convinced that Ive got to build a mini tanto.
Bought a motor today and its seems nice best bit is its 1/2 the size of the motors in Tanto.
type of bot- rambot
height- 150mm
length-275mm
width-300mm
speed-approx 15mph
drive-technobots medium power drive
power- 2x24v 1400mAh NiMH
chassis 6mm T6
Armour- proberbly 6mm poly
weapon-rambot the mini version of The full body hammer
status-collecting parts gimme a while
where did you get the inspire dvd? i put my name down for the advance purchase at the event and then again on the website and havent heard anything since.
Ed was selling them at Brighton, but my current understanding is that competitors will get a free copy, which will also contain more than the version being sold over the weekend.
Type - 4WD Invertable Vertical spinner
Height - 180mm
Width - 388mm
Length - 480mm
Speed - dont know
Drive - 2 x 12v drills at 24V
Power - 24V NiCad
Chassis - 12mm and 6mm Polycarb
Weapon - 150mm diameter spinning disc powered by an EV Warrior
Status - Drawn up on autocad, starting to collect parts, will not be operational untill P.I.M.P.anought gats trashed/retired so i can steal speed controlers etc.
forgot, I got a featherweight running at the moment in the league.
Half-wit
Type- simple melty brain, kinda like gentle heater brain
Height- 120mm
Length- 450mm
Width- 450mm
Speed- um.... 20ish mph, dunno
Drive- 2 golds, might do something clever with em later.
Power- 21.something volt nicads, going up soon
Chassis- all ali, mothing special
Armour - again, basic ali.
Weapon- it drives in circles and has big teeth (grrr)
Type- Full Body Spinner
WEIGHT - 6KG!!! (why cant i build a 12kg feather lol)
Height- 12mm
Length- 300mm
Width- 300mm
Speed- unknown
Drive- 2 x 12v 35W Bosch Motors
Power- 2 x 7.2V 3000mAh NiCads
Chassis- 10mm Polycarbonate
Armour - 2mm Ti
Weapon- Spinning Ti Body with 12 teeth
Status- Chassis built waiting for drive axles and body! before some real testing is done muahaha
