Featherweight Database
  • #46
    Robot - G-force (currently)
    speed - Damned if I know
    power - 24V Slas
    drive - wiper motors
    controller - 15amp electronise cpus
    weapon - lifter
    armour - 4mm polycarb, 2mm Ali
    Status - Being put together for some practice until I get the bits for Ami 4 or get Ami 3 back from Gloucester.
    • #47
      Robot- Micro-Maul II
      Speed- Calculated at 20mph
      Power- 14.4v ni-mh (drive) and 24v ni-cad (weapon)
      Drive- Secret drill motors
      Controller- H5 speed controllers
      Weapon- 1400rpm vertical disc, designed for high torque flipping of opponents. Geared 6:1 off weapon motor.
      Chassis- 4-6mm polycarbonate
      Armour- 8mm polycarbonate and 2mm titanium
      Features- 25cm disc at front and can run both ways up (youll have to wait to see how it does this)
      Status- In the build, its first event will be 2004 featherweight smash (6th march).
      • #48
        Weight:12kgs
        Power:2x 12v 2.3ah slas
        Drive: 2x 24v gold motors running on 8/1 reduction
        Speedos: 2x 15a cpu electronize
        Weapon:ramming robot
        Status: being built / ready for fw smash 2004 prob
        regards
        kenny
        teamkenny
        • #49
          Name- Mini-Maul III
          Weight- 10kg
          Power- 1 x 3300mah ni-mh pack
          Drive- 2 x 12v motors at 14.4v through 1:6 ratio
          Speed- 20mph
          Controller- H5
          Weapon- 5cm spikes and wedge
          Status- Moving about very fast and hitting stuff, If all goes well then this will enter the fw smash aswell as Micro-Maul.
          • #50
            Name- Mini-Maul III
            Weight- 12kg
            Power- 1 x 24v ni-cad
            Drive- 2 x overvolted windsceen wiper motors
            Speed- not yet built but calculated at 6mph
            Controller- H5
            Weapon- 1.5kg axe powered by a 1400rpm gear-motor at 24v axe hits at 60mph
            Status- being built, parts from mini-maul III, above, go into Micro-Maul II
            Notes- Terrorhurtz featherweight lookalike, to be made completely out of polycarbonate...
            • #51
              Another RobotWasnt even a week before the other one got to paly that ur building a new one. How about you sort of hmm spend a month or 2 building one, then when its mvoing around and ur happy with it, then sign it up for an event and database? Think you could do that Ewan? Would be doing you a big favour.
              Mr Stu
              • #52
                I want to enter the FWS 2004 with a good robot for once, I test all the robots I build, and if they fall below my expectations... I build a new one.
                Ive lost count of all the ones Ive built so far
                • #53
                  Ooook - keep going then.
                  Mr Stu
                  • #54
                    you mustnt have very high expectations!
                    • #55
                      no comment
                      • #56
                        Sorry Ewan but there already is a featherweight version of Terrorhurtz, Ami 3. But as Jon said above it is still down at Alans in Gloucester, if we ever get it back to finish building it, its axe may be rubbish but it does work. And as far as I remember our team were the first to have an axe on a featherweight, someone correct me if im wrong.
                        • #57
                          Ed it dont matter if there is already is a featherweight version of Terrorhurtz, I mean its not very original of Ewan but he can still build one like that design, there is at least 2 feather versions of Pussycat with the official one being Kitty.
                          Chris - http://www.featherweights.org/forum
                          • #58
                            I didnt say he couldnt build one just said one already existed, anyway ours isnt working at the mo.
                            • #59
                              Full Name : Possibly Indestructable Mechanized Plaything, will be called Plaything or for events (to avoid causing offence).
                              Power : 25.2V NiCad
                              Control : 30A Electronize (Ext Relays)
                              Drive : 150W Gold Motors 2 stage 8.8:1 reduction 120mm wheels (50mm wide)
                              Armour : 2mm 2014 T6 Aluminium everywhere + 2mm poly on front, back and sides
                              Notes : Invertable 4WD red box but not a copy of Tornado. Can drive pretty fast with me standing on top of it.
                              • #60
                                Theres a pic of the mini terror hurtz (ami 3) on the http://www.lambsy.co.ukwww.lambsy.co.uk go to lambsy...events....kettering its in there some were i think... I also belive Gord was planning a mini THZ...he might have gone of the idea though?
                                regards
                                Dave moulds
                                Team Turbine/PLF
