now im gonna juse 2 gold motors to power my 4 weels. 1 or 2 HTI motors to power my spinning disk. and SANYO 3600 nimh accus. and make one blok of accu (14.4 volt to power my motors.
I think it will do, if you get the gearing right. The lower the rpms your motor due to a too a poor chosen gear ratio, the more amps you will draw. And with four wheel drive which tends to draw more current to make corners anyway it is very important to keep a good gear ratio.
I dont know the specs for the HTIs exactly but they seemed like high power drillmotors to me. As long as they get the disk quickly up to speed, the current draw should drop quite quickly.
All in all it will be close, but I think 12 cells should do it. Specially since those Sanyos are great cells, they do pack a punch.
While on the subject of motors. I just bought a second hand Astro cobalt 940. I saw on the Astroflight website they are discontinued, anyone know a place where i might find a replacement in case of an emergency?
According to the Astroflight site the 940 is still listed. http://www.astroflight.com/e/env/store/store-Industrial.html?sid=0001a0PRDdPofIgqdM7S401&link=/store/store-type-tem.html&item=products:af-940http://www.astroflight.com/e/env/sto...001a0PRDdPofIg qdM7S401&link=/store/store-type-tem.html&item=products:af-940
They have changed the design slightly but it is still the same specs.
Stats for HTI
Power 0.35 hp @12v 1.43 hp @24v
Torque 0.47 lbf*ft @12v 0.97 lbf*ft @24v
Efficiency 70% @12v 76% @24v
Speed 1260 RPM / Volt
Voltage 12 volts or 24 volts*
Weight 11 oz.
Output Shaft 5mm dia x .75 long
Diameter 1.7
Length 2.8 (from face)
Face Mount 2 M4 holes 1.14 apart
ok so its beter to juse belt drive everywhere...
i will take a look how the HTI motors will preform on 14.4 vols, and if it prefomes bad ill take 24 volts...
