Electrical problem in new bot
  • #31
    No , there is a little diode that is on the IBC that lights up when there is a voltage connected to the IBC , I have examined the board of the IBC and i can see nothing has blown , so I am guessing it is a loose connection somewhere .
    • #32
      check the underside of the IBC as it blew a track on the pcb not a component. Is the jumper secure on the IBC for the BEC option?
      • #33
        Nope no track blown on the IBC , and the BEC jumper is on , but still cant get it to work :sad: . May have to bring it to the next event I am at and get someone to look at it , but i am still searching for the problem .
        • #34
          Ok took it to the guy that does my electrics today . The voltage from the battery is getting down the battery wires , so it wasnt a loose power pole . Still have no idea what the problem is though . If worst comes to worst ill have to ask someone for a lend of a speedo for the FRA Champs :sad:
          • #35
            Alistar i have 2x 15amp electronize controllers if there any use to u? , im at the champs all week, i have nothing better to do
            • #36
              Thanks alot Craig ,I will keep that in mind . My robot is running 4 x 18v drills @ 24v if thats any help .
              • #37
                Alistair, If you end up running with the 15amp electronize i would only use 2 of the drills as 4 may smoke it.
                • #38
                  If worst comes to worst and that happens you can just extract the gears from two of the drill gearboxes so that two of the wheels can spin freely
                  • #39
                    I run 4 x 18v motors at 24v on Dragon 2 from 2 Electronize 15amp controllers blew the fuses a couple of times so put 20amp fuses in blew these once but have not had a problem with the controllers for the last 10 months
                    (Message edited by dragonmaster on August 14, 2006)
                    • #40
                      i run 30 amp fuses in the 15 amp electronize without problems. if you are worried, turn the gain down so each drill gets 18v, this is still pretty powerful, and 4 drills at 18v is better than 2 drills at 24v.
                      • #41
                        Well Alistair, the offer still stands id rather u blew up my electronize than pulled out of the comp but thats jus me,
                        it wouldnt be the first time i stripped my robot so that another robot could carry on in a competition,
                        • #42
                          Hey Alistair, Ive got a pair of 30amp Electronizes with the relays sitting about that I could lend you if you want.
                          Theyre in my bot doing absolutely nothing at the moment and seeing as its not going to the champs, Ive no immediate use for them. Unfortunately Im not going to the champs either but I could post them to you beforehand if you want a chance to install and test them.
                          It should be fine for the four drills, cos thats what Ive been using them for so far, and theyve been fine so less chance of them getting damaged - unless Scorpion (or any other spinner) sinks its disc into them Drop me a mail if youre interested (or MSN, Ill prob be on tonight)
                          (Message edited by K_C_R on August 15, 2006)
                          • #43
                            A real big thanks to everyone that has offered to help me !
                            Jamie , yours sound the most ideal so I think that i will go woth you , ill talk later on MSN . As for wiring the speedos up , how will i connect the the two battery wires from each onto the one battery ?
                            • #44
                              Solder/connect em together
                              • #45
                                Ill stick a little diagram in with your order.
