Advice on betteries please...
This topic is closed.
    If you go to chargers and PSUs at http://www.technobots.co.ukwww.technobots.co.uk - both the 13.8v 20amp Power supply (1090-016) and the 13.8v 20A Dual Output Power supply (1090-017) are both ideal not to only run 1 of your chargers at MAX ratings, but attualy 2. I think they say you need about 8 or 9amps supply to each charger for it to work to its max. So a 20amp supply will quite happily do 2 chargers. And the cheaper one at £34.12 which i use, does one charger perfect, and also ran 2 chargers without problems when people borrow the supply from me as well. LOL - *COUGH* Pete/Jonno *COUGH*.
    Mr Stu
      We had this problem with three different power supplies that we tried. In the end bit the bullet and bought a big one from Rapid Electronics. Many teams use the same one. (order code was: 85-182 Cost about £110 inc del.
      Chris stick with the botpacks if you can otherwise, race packs/indivual cells, if your confident of making up good packs, of GP3700 NiMH
        We use one of the 40A power supplies - theyre £136 plus delivery from Technobots (so about £140) but you can get the same charger from Rapid Electronics for £109 including free delivery
        Link on the Rapid website is
        http://www.rapidonline.com/productinfo.aspx?kw=85-1828&tier1=Electrical%2B%26%2BPower&tier2=Power%2B Supplies&tier3=Switch%2BMode%2BPSUs&tier4=25A%2f40 A%2BSwitch%2Bmode%2Bpower%2Bsupplies&moduleno=6506 3http://www.rapidonline.com/productin...rical+%26+Powe r&tier2=Power+Supplies&tier3=Switch+Mode+PSUs&tier 4=25A%2f40A+Switch+mode+power+ supplies&moduleno=65063
        Weve had ours for around 3 years now without any problems.
        Ed
        http://www.teamstorm.comhttp://www.teamstorm.com
          Ed I wish you had put that post on here 2 weeks ago
            Sorry Gary - if its still 7 days from the day after they were delivered to you then you can always cancel your order (Distance Selling Sale of Goods Act) however if its after then theres nothing you can do :sad:
            Sorry !
            Ed
              ahh dont worry about it. I have one and it works fabby so I am happy. So much better to be able to charge a hawker in half an hour rather than a few days!
