Could anyone give us some advice as to improving the batteries in Push n Shove as the ones weve got seem to keep letting us down! The bot is a 4WD pusher wired in parallel with 4 12V drill motors, 2 electronize speedos and 2 12V drill batteries. Wheels are solid rubber 75mm diameter. Wed like a bit more speed and something more reliable (they either run out of charge part way through a battle or get too hot). We dont really want to spend a fortune though!!!
Advice on betteries please...
Slightly higher voltage and more amp hrs.
14.4v perhaps?
Cheap .......you could perhaps consider a better drill battery/s .....perhaps something like this?
http://cgi.ebay.co.uk/BOSCH-14-4-VOLT-2-6ah-NiMH-BATTERY_W0QQitemZ300008776047QQihZ020QQcategoryZ20 777QQrdZ1QQcmdZViewItemhttp://cgi.ebay.co.uk/BOSCH-14-4-VOL...300008776047QQ ihZ020QQcategoryZ20777QQrdZ1QQcmdZViewItem
a set of average nicads/nimh from my store, or any store for that matter (providing they are new or almost new condition) should last you perfectly well as a 14.4v pack.
paralleling up the drill batts was only needed as they are really low quality. anything on my store list will work fine without paralleling up neccessary.
prices from £8.50 per 7.2v and you are sure of their quality, be careful buying on ebay, batteries have a lifespan, you may be getting batteries at the end of theirs
yep i agree with JB there, it is risky buying batteries from ebay!
Cheaper batteries would be ok if you could wire up another set in parrallel to give it the same voltage but twice the amperage-but its a big waste of weight. 2400mA nicads/NiHms should be perfectly fine
If a pack has not ever been charged then they will stay as new untill charged! thats why lots of companies buy in bulk because it doesnt matter when they are sold.
If it works out cheaper buying the 3000mA batts then i would say buy them for deffinate, but if those drills are cheaper i would go for that option, but its upto you
Rather than start a new thread, im looking to replace my batteries in Conundrum Mk2 before the champs, what do people recommend I get and where from. Keep in mind that I am running a hungry Ev warrior and a couple of drill motors, at the moment it seems to run ok on two heavy 3Ah 12v BotPacks, just want an upgrade.
Chris - ^_^
I am having a problem charging my batteries . I have a modified PSU and a Pro Peak constellation charger . When ever i want to charge my 3300mah 24v pack at anything over 2 amps i get an error message saying Input Voltage 11.60v Is there a solution to this ?
We had this problem with three different power supplies that we tried. In the end bit the bullet and bought a big one from Rapid Electronics. Many teams use the same one. (order code was: 85-182
Cost about £110 inc del.
Chris stick with the botpacks if you can otherwise, race packs/indivual cells, if your confident of making up good packs, of GP3700 NiMH
