I’m hoping that I understand what you are meaning - I’ve found that so long as the weapon can be locked in a specific safe position it will pass the safety check. For example, Strix’s weapon is operated by a linac and locked when the flipper was wide open, but if I could design something that speficially locked the flipper when half closed I imagine that would pass checks too. It doesn’t have to necessarily be at the end of a weapon’s travel.
I would personally just operate the jaws to a fully open position at the end of each fight and shove a chunk of hdpe between them to stop them clamping down.
Also my linac could probably travel like 5mm-10mm before it came into contact with the bar. Within reason, it doesn’t have to be a 100% press fit. So you needn’t worry about getting the weapon in literally the exact same position each time.
i guess you could make some sort of adjustable locking device but I think that’s more complicated than it needs to be.
Hope that helped somewhat. I actually made my locking bar at the event itself, I’m sure you could do the same if you are unsure about what would be appropriate.
Yes, so this is Amnesia as in the FW champion Amnesia, so (with all respect to Theo and BWX) a slight step up in terms of the opponent intimidation level. It seems like the sportsman competition has become more of a "no spinners" affair, rather than the "beginners and bodgebots" that is was in January...
