The gears in the carrier themselves are fine, it is the actual axe motor gear that is slipping. I think what has happened is when I drilled the holes for the motor face bolts I drilled too big a hole because I couldn't line them up on the HDPE sheet (I was lacking a pillar drill at the time, which I now have).
The quick and dirty solution is to slide in a bit of 2mm HDPE underneath the motor to raise the front of the motor up to mesh properly. Longer term is to rebuild the carrier entirely as described.
The drive motors, I think either the motor or the wheel itself is out of position. I suspect the latter but will measure.
