Since I am trying to update this semi-regularly, here is a post for this month!
Been quite busy recently so proper building for the Super Actuator only began about 2 weeks ago. I have tweaked the cad a little, but it's slowly becoming a real thing:
At this point I have cut everything I can with my tools, except some thin teflon which I will use to reduce friction between the rod and barrel. Next up is the tricky part - drilling the holes so the gears mesh properly and so that this will fit together. Then I will mail it down to a friend who has kindly offered to help with milling/lathing.
Still a bit cautious that this thing won't work and could break itself, but so far all is going to plan!
 After countless failed attempts, I've had to accept that making this with a cheap pillar drill and hand tools will be very difficult. I just don't have access to the precision that I need. However, I'm glad I tried and I've not given up completely, but for the time being I'm going to fall back on modifying a stock linac with a brushless motor. If I have time before the champs I will definitely try the "Super Actuator" again, as I still want it ready for that.
