Updates to be made! Just got back from the Gloucester event - brought along V1 again which I used to test out several of the parts and design tweaks I'll be using in the new build. For 6 fights of the event I ran the machine on the two small 4 Cell 15.2V LiHV packs in parallel, and the 12v argos drills handled it with no problems at all. I think the machine was a bit faster and more powerful - it's quite hard to tell the difference when the arena is so big and I'm only upping the voltage a little bit. The new front wedge was also low enough to get under Explosion and Heatwave once or twice - the old one was hopeless and I would always lose wedge vs wedge contests. Was still a bit too steep to reliably get under robots easily, and it still seems to lose all most of its traction when upside down, but overall the robot was the best it's ever been, so things are looking up for this new build!
A few changes to the flipper setup - Will still try the 1500kv Outlander motor, but I've changed the actuator for a HIWIN 18v one as on ebay they were half the price of the gimson 12v actuators and seem more robust, whilst being roughly the same weight, speed and also having very similar dimensions. (I think it's the same model as Aegis?)
Also some tweaks to the CAD to cut down weight in some areas and beef up the armour in others. Flipper panel + hinge mounts are one piece of bent hardox and there is now a small sloped 15-10 mm HDPE lid. Wedge and flipper are now 4mm hardox, sides are 20mm HDPE, and the rear is 15mm. Side panels are now also bolted to the inner bulkheads at the front as well, rather than just the middle. Great suggestions with the polycarb, but I think I'll be keeping the wheels exposed or else the robot will look quite similar to the new Rapid/Astro.
Had a quick ask around at Gloucester what people thought of potential robot names. At the moment I think Strix has quite a good ring - it's a vicious bird from classical mythology that was a sign of bad omens.
Interestingly it still wasn't anywhere near full power though - I think I only increased it by about 25%.
