Originally posted by typhoon_driver
View Post
Triforce 3 - Build Progress Thread
Got all the welding done over the weekend, its now actually starting to look like a finished bot (minus assembly).
The ring with the gear welded inside it.
All the plates, still need to go round them with an angle grinder and clean them up before I paint them.
The bottom plate warped quite a lot, so will need to put a bolt through the center and pull it back down flat.
Drive unit meshes in the gear!
Just need to put the thing together, wire it up and paint it now. Next thing is to test the drive with full weight.
Which teeth? The big ones on the ring I am a little worried about. So we are getting a second ring made all in one piece for fighting spinners. Also works as a spare when the teeth fall off the welded one.Originally posted by maddox10 View PostI have to admit. Impressive in total, but I'm not so happy on the welds. Especialy the ones for the teeth scare me.
The big teeth that do the work destroying the opponents. A Monoblock spare disk is a good plan. I think you'll need it.
On the gear-rings. I hope you will do the spare disk with full length teeth.
We stripped Mod 2 gears in Kashei, our featherweight with an electric axe... Just to give you an idea.
The main progress the last month has been on the electrical side with the A200S controllers now working properly (See this thread), on the mechanical side it has mostly been grinding and painting.
Assembling some ESCs, they stack in the bot sharing heatsinks to save weight.
Grinding and painting. The extra bar on the bottom plate is to reduce the warping enough to put it together lol.
The weapon module is finally finished. Weighs 15.4Kg which is only 1.8Kg more than an Etek-R, but 2-3x the power.
We gave it a spin with a drill and it works really well spinning the ring. Now just to hook up some batteries and see how much power it takes to start up the ring.
image-20180222_185730.jpgimage-20180222_185744.jpgimage-20180222_190153.jpgimage-20180222_190209.jpgimage-20180222_190224.jpgimage-20180222_190310.jpgimage-20180222_190359.jpgimage-20180222_190557.jpg
