INSOMNIA 61
Belts and shaft arrived the day before the event so frantically put it all together that night and boom, the ESC blew testing the drive with belts. Thanks to Dave W for lending me his FeatherTwo which was perfect, will be getting myself one rather than replacing the Scorpion XXL. So, all together all wired up at the event:
And in weight and with 900g to spare!
Fed it some wood on the Friday for tests and utterly demolished it
Starting to believe it could be nasty! So, draws done, and I get:
Impulsor and Persephone - Two wedgebots
Legion and Binky - A flipper and another big vert disc
Neon and Steve - MASSIVE undercutter and grabby wedge thing
Shard and Carcinus - Horrible vert disc and horizontal pinchy thing
Starts pretty nice and gets progressively nastier!
Fight 1:
https://www.youtube.com/watch?v=s74CsSl9vMA
Ok so it hits harder than I expected
Impulsor is all mild steel so when I hit it I left a massive cut down the side, top to bottom:
As for the other one... ow?
I was taken aback by how well it performed in its first fight, I was expecting something to break or explode but it came out and only needed the battery charging! However at this point I did realise it was drawing too much current for the battery and had used half the capacity in that one 50sec fight alone :/ . So I guess keep fights short!
Fight 2 never happened, Binky and Legion withdrew and I got a bye for max pts which put me on 8 for the first day of fighting
Fight 3:
https://www.youtube.com/watch?v=9sGtEMQ6-jE
I think that may be the biggest impact of the entire competition! Neon ripped out the drive link and one of the shaft bolts sheared, bodywork damage was non existent bar a few dents on the disc. Most of the damage was self inflicted; the disc managed to hit the motor pulley and destroyed one side. Motor circlip imploded but the motor itself was mostly fine. I had a spare but left it in as I would rather not put in the brand new motor just for it to get killed against Shard later on. I removed the snapped rear drive shaft and replaced it with another, good as new.
SLOWMO IMPACT GIF
Fight 4:
https://www.youtube.com/watch?v=3yx7ZpeU4ew
succ
Carcinus wasn't around so I just had a one on one with Shard. So I had a throttle cut setup on my tx to limit the throttle to 50% to prevent gyro, unfortunately if its on when the robot is powered on it prevents the weapon ESC from arming so on activate my weapon wouldn't spin
By the time I realised it was already too late and it was in the Standard Ripto Loss Position:
Sad
But at least its authentic to the original I guess, and I think I would've come off with a lot more serious damage if I hadn't got stuck
So the last place and second place gained me another 3pts bringing my total up to 11pts. They informed us that there were 2 too many machines on 11pts for us all to go through, so we would have to fight in two 3-way melees to eliminate the two extras.
Fight 5:
https://www.youtube.com/watch?v=r4F7o3KUXcM
BOOM
No real damage to Omega, that things a brick. However you can see the belt come off after the hit; The disc actually wobbled a tiny amount and hit the pulley again, this time much harder, snapped the shaft clean off, pulley and all. So, replaced the motor with the spare, and repaired the other drive shaft which had bent and come loose as well.
Obligatory gif I can't stop watching
THROUGH TO THE FINALS
And still looking pretty damn good despite those big hits!
Draw for the finals was done, I got Straddle aka British HUGE.
Straddle's a weird one, a hybrid of Gabriel meets bar spinner than really I had no idea what to do with
cont...
Fight 1:
Fight 3:
SLOWMO IMPACT GIF
Fight 4:
succ
Sad
Fight 5:
BOOM
cont...
