So a rear strengthening plate has been added in for the rails, front and rear blanking plates are added in and a crude hinge has been made for the front deflector plate. All a bit of a rush but fairly confident at this point it will go to EXR Guildford (and hopefully not get trashed this time around).
I may very well end up having to finish this in the pits though. It runs but it has no weapons at the present and no rubber on the wheels. Impressive drifting will ensue but it is barely controllable over 40% or so.
						 If it's any consolation, the flipper also took my wheel off with enough force that a bearing came loose inside the gearbox, which after a few more fights has ultimately killed it. Looking forward to seeing the brushless Badger.
