Team Kaizen - The Honey Badger
  • More good news, the brushless motors turned up today. It is a bit smaller in length than a 775 motor but significantly wider.
    They definitely feel like they mean business, certainly weight 500g a piece but I now need to consider how to get the power to the wheels. I think a toothed belt drive might work here as a "simple" solution but I've never made a powered shaft like this, nor have I ever secured a shaft to a plate.
    Am I right in thinking the "quick and dirty" solution is to get a shaft, two HDPE plates, drill a hole in both of them, run the shaft through those holes and then use a collar on either side to hold it in place, ending up with 4x collars? I guess for the pulleys, I'd need to flat off a little section of the shaft and then use a grub screw (or drill the shaft completely and bolt the pulley in place) to hold it in place? I guess the speed means a bearing in the 10mm thick plates might be needed here?
    Alternatively, I suppose 2x pillow block bearings and drifting the shaft through them might be the more robust solution?
    • Just catching up on your build and adventures in Manchester. Took ages so much happened and so many comments.
      It was a shame how hard you got hit, when you are the most prolific contributer to these pages.
      Looking forward to seeing V3.
      • any reason why you can't use the gearboxes from v2 ? or are you trying to leave them intact ?
          Thanks, these things happen and it isn't like I've not rebuilt The Honey Badger 2 in a rush before :P
          The shaft on a 775 motor is 5mm, these bad boys are 8mm. I guess I could try and find a 9 tooth gear that goes on a 8mm shaft (not sure there is TBH) and then fashion up an adapter plate if the motor mounting holes don't fit, which is likely.
          • according to hobbyking it says it 8mm. You could try and find someone who is willing to turn it down to 5mm but I would make a custom gearbox similar to what you find in a speed 900 gear system (hardwired II)
            Photo from hardwired II (Matt Smith)
            • I was about to say, I've taken the Gimson gearbox apart on the poorly motor and I think I might be able to use the existing shaft (if I can bore out the pinion gear to 8mm) and lose a single stage of the gearbox. Once that is done, the extended shaft fits in the gearbox with the adapter plate to the 775 motor only needing a little bore out to make it fit onto the motor.
              My next engineering challenge then :P
              Do you mean the brushless motor I am using?
              Also, I can't count, it is a 18 tooth gear, not a 9. In which case, according to gearsandsprockets.co.uk, I can get a MOD 1 18T to fit on a 8mm shaft. It definitely is promising though.
              • I've been using the gearboxes off the very Gimson motors you've been using with 4248 outrunners. Had to find a suitable pinion, but it mated pretty much straight on
                • Sounds promising then. As described above, it isn't quite as straightforward fit with this motor but I've ordered a couple of pinion gears so I might have it running on these motors fairly soon.
                  • Well... one of them is kind of working...
                    Perhaps if anyone could advise me as to why the motor is acting the way they are, I'd be most grateful
                    • Have I just replied to this same issue on Facebook?
                      • I wouldn't have thought so, I don't have a Facebook account of any variety.
                        EDIT: Looking at a video which is kind of similar, I think I have a bad connection somewhere, which is likely given how pants my soldering is (despite doing plenty of this at Manchester with Chris from ARC Robotics :P). Will dig further.
                        • These look like the RedBrick 125A ESCs. You mention using a different hex file, is this labelled rb70a3?
                          • They are 100A v2 Redbricks, so using the rb70a2.hex file.I need to figure out how to use the kkmulticopter tool to reprogram it to give me reverse. I know it is a boolean switch from 0 to 1 but I can't figure out (yet) how to get the code to load.
                            • Ah, OK. Do you get the three audible beeps at different frequencies on powering up the ESC? I couldn't really hear in the video. If you only get two, the one phase is missing and that's the difference in V2/V3 pinout. I had the same at first on the 125A.
                              • I get 3 beeps when the power is turned on and signal is acquired.
