Originally posted by Giles
View Post
Team MeltDown Build Diary
So most of you probably followed the build on facebook, but if you didn't then here are some pictures. I stupidly didn't take any shots of finished mantis before its fights, so if anybody has a picture of that I would like to see it!
Wheels and molds for them:
The hubs. Printed in Carbon/Nylon
The grab actuator block
Waterjet parts
Assembly
Last shots I have are before adding the wheels and wiring.
Yes I did! Only won one fight out of 5 however, with the 5th one (Conker 3) doing too much damage to my internals to carry on for another fight. Extremely fun bot to drive (hard to control the claw), I think it has potential with some improvements. Definitely popular with the crowds.
Mantis 2.0 build is in full motion!
Mantis V2 is designed to fix many of the issues Mantis v1 had. It's now on entirely brushless drive and lift motors for better driving performance. It's using 4wd belt driven drive pods with 80mmx50mm wheels for good traction. The frame will be made from 2024 Alu and the outer armour is a mixture of 5mm grade 5 titanium and hardox. Claws are now 5mm gr5 titanium too.
A big upgrade to the design is the new claw which uses only one motor to grab and lift, this will simplify driving and hopefully make the bot easier to control.
Some CAD pics, one showing the close up of the new lifter gearbox for extra lifting power (64:1 saturn, 2:1 gearbox, 3:1 pulley)
Here are some of the CAD renders. Close up on the lifter gearbox, hopefully a more robust solution than Mantis v1.
Drive pod bits, these are all 6082 alu with steel wheel axles and gears. Wheels themselves are cast polyurethane 60A using 3D printed nylon hubs and 3D printed molds.
These are all the nylon printed parts in one wheel pod:
And here is a jumble of bits in the works, upper claw, front armor pods, pics from CNC shop of frame in progress and the lift motor connected to a 64:1 saturn...
A fair bit left to do, but things are shaping up nicely. More updates to come
nice. is it a local firm to yourself as it would be nice to who did it that's allLast edited by Maxamuslead; 20 July 2017, 17:11.
Firm doing the CNC is in Ireland, so not local, but he's a good guy.
@Andy, some of the internal mounts are 6082, the claw standoffs are 7075 and the frame is all 2024.
@Maxamus, Mantis 2 will be somewhere between 13.2 and 13.6 I imagine, CAD is saying just below 13kg right now, with small wiring bits missing. 2024 is 2.78g/cm3 and 6082 is 2.71g/cm3, so the difference is minimal.
hmm ok as the info i got from here says other wise. meh it is the internet it's fully of liesOriginally posted by Giles View Post@Maxamus, Mantis 2 will be somewhere between 13.2 and 13.6 I imagine, CAD is saying just below 13kg right now, with small wiring bits missing. 2024 is 2.78g/cm3 and 6082 is 2.71g/cm3, so the difference is minimal.
http://www.makeitfrom.com/compare/20...96082-Aluminum
