Bw: Tmd.
  • #46
    Lol thanx. They're hanging around and I'm not using them, and were only a fiver or so from some ebay seller lol. When I first started building chopping board creations everyone gave up their tips and tricks, to the point where Razer Dave rewired my Sabertooth at Doncaster. I wouldn't have gotten something into the arena without a lot of help from everyone.
    • #47
      Thanks again dave
      • #48
        Sent you a pm dave
        • #49
          Ok no worries will have a look now
          • #50
            Hiya, sorry to post on your thread. I keep meaning to tell you that these hubs
            http://www.technobotsonline.com/polo...-mounting.html
            will fit the motors I've sent you. You can then attach any wheels you fancy, even make your own wheels etc. The Banebot's wheels are available with hubs that will go on a 4mm D Type output shaft, but they're an arm and a leg. From what I understand, they also take ages to arrive. Your other option is from Fingertech where they do a similar sort of thing. I think they're from Oz so will also cost an arm and a leg but they look a bit posher to go with the Lite Flite wheel set-ups. Hope this helps.
            http://www.fingertechrobotics.com/pr...d=ft-snap-hubs
            • #51
              Thanks for that dave, will probs use the pololu ones as I've used them before
              Agree with what you said about banebots and fingertech taking ages to get here
              Btw, fingertech robotics is in canada
              • #52
                Ohhhh ok! Didn't know they were Canada!
                • #53
                  Thanks dave, theyve arrived fine
                  Sent you a pm btw
                  • #54
                    No worries buddy gimme a shout if you need any help.
