Originally posted by Max
									View Post
Richie: The £50, 3 week Featherweight
 Yeah the floor flipper was showing no mercy at that event, but at least the crowd enjoyed it! (@ Jarvis: When are the videos going up? I wanna see how Richie landed so I can get an idea of what's probably damaged ) )
 On the batteries; the peak working current I'm ever likely to be drawing is probably around 30A, so one of those cheap 2200mAh 20C should be fine. I'll buy two just in case; at just over £6 each, I think my budget can stretch to that! As for the rest of the upgrades, I think I can manage them all without further spending (aside from maybe a fixings):
 I've got some small aluminium box section for the self-righting wings; the rest is just string and elastic bands!
 I'm planning to build the front drive belts using some slightly springy, heavy duty string sprayed with belt dressing (The round belts on RS were ~£13 for 5m, and could only take 5Kg of force unless you went to the really expensive stuff). I'm probably gonna have to do a fair bit of experimenting with the drive belts to get something that works reliably, but if they fail in a fight Richie'll still have drive, so it's not too big a problem.
 As for spinner proofing, I'm planning to securely attach some ablative bulkheads to the chassis (Aka, bolt on some 2x2 from the firewood pile; gotta keep up the 'rustic' feel :L)
 I'm gonna try and keep it looking like a fighting robot rather than just the heavy duty arts and crafts project it seems to be turning into; this is quickly becoming an exercise in 'Redneck' engineering at it's finest
 Ok, so minor change of plan; Planning on going to the fight at Guildford, but only have 2 days at home before then in which to repair Richie and make some mods. So I'm going to just upgrade to a LiPo battery, fit new wheels and motor mounts, and fit a self righting mechanism and maybe some extra armour if I have time.
 What I was wondering was I've been thinking about getting a set of these wheels http://www.ebay.co.uk/itm/280590873668; I was originally gonna make some from scratch to save money, but due to time constraints and what with these not being very expensive, I thought it might be worth a go. Has anyone had any experience with these/ this type of wheel? Are they actually any good?
 I was actually considering a set of those exact wheels for Hatchet 2, may have to reconsider now. Having seen the BB wheels on some of the machines at this years champs i can say that they do seem to offer a fair amount of grip and they also seem to be fairly tough, if you don't mind paying the extra i'd go for those.
 At ~£2.50 each it's still not a bad price..
 Are http://www.bearingboys.co.uk/BZMM80W...e_Wheel-8714-p the high grip black ones you were talking about? According to the data sheets for these wheels(http://www.bilcastors.co.uk/images/c...ls-Cat-Ed4.pdf) the blue ones have the softer tread so should in theory have the better grip and wear the fastest... ?
 Bearingboys didn't actually do a small enough version of the blue wheels, but I found an 80mm version sold here: http://www.bilcastors.co.uk/bzmh80wrn-p-1286.html. They're a bit wide, but could be machined down a bit to fit I think...Last edited by Rapidrory; 25 May 2014, 23:45.
 Rory, not a bad find
 The shore value is a little high. The preferred orange or blue ones from banebots are either 40 or 50 shore
 Maybe their nylon wheels and bike tread http://www.bilcastors.co.uk/solid-wh...s-c-54_56.html
 Well I've got several of those white nylon wheels at home (or at least used to) so that may not be a bad shout... They seem a little brittle from what I remember though; I'd have thought they might crack if you put screws in them...
 Now there's the problem that I don't know if I still already have a set of white nylon wheels, and I wouldn't have time to buy them if I get home and not. Plus, though they're only 80p each, they have £5 shipping on them, so I don't want to buy a pair to find I have loads at home... I'll have to give my dad another thing to search for!
 They're a nice wheel and they feel pretty solid, not battle tested of course. I choose them because they are cheap which means you can have lots of them. When you hold them in your hand they are a nice wheel and certainly not brittle. I used the 'melt-in' method in my drill press and the shafts dropped in easily without compromising the hub strength.
