Yes it does fit in the bottom, I noticed at the NEC that it would be good to have a one stop wheelie toolbox. The hardox jackets are made there are pictures further back in the thread.
Team Sabretooth
So they are, my bad!Originally posted by Gabe01 View PostThe hardox jackets are made there are pictures further back in the thread.
I'd say for a pneumatic robot, it's pretty compact. It's maybe just the arrangement of the bottle/buffer and general closeness of all the components; could well be much bigger in the flesh.
So today has mostly been trial and error finding space for everything, I think progress is being made. The robot is 370mm in width and so its tricky to fit all the components in.
looks sweet Gabe- if your tight on space you could change the fittings coming out of the trev reg down to 6mm OD pipe?- would do away with all those elbows etc and you wont notice any difference in flow id expect... its only between buffer /valve / ram you need big pipe
pneumatic change
So on Mouldy's advice and re-visiting Chris's thread (liftoff) I've switched the sizes from 12mm to 6mm and re-plumbed 'Legion'. I am very pleased with the results. I have also purchased myself some scales as I was beginning to worry about weight. needless to say I am on track with the weight as well so thats all good.
an aside I enjoy looking through and reading other peoples build diaries, I especially enjoy the photo's with this being said. Get busy
Mouldy, Chris, EventHorizon, Ellis,Dave, Matts, James and Gary to name but a few. Your sheds must be bulging so share
What is the tolerance on them? Could they cope with weighing beetles? So + or - 5g or less.Originally posted by Gabe01 View Post
