New Video is finally up, it is a long one but as mentioned in the video i'll be doing videos throughout the rest of the build to show what's going on. http://s921.photobucket.com/user/mrs...0ed58.mp4.html
Boring Brick
No real progress made i'd just like to share my latest cock up, so after taking the body off the bot yesterday to loctite the threads i was interrupted by my son waking up crying ( he's 18 months) and failed to notice that i had left the HDPE body by a radiator which subsequently came on quite hot, so this morning i go to fit the body back to the robot and find that it is now warped and no longer fits properly, and as i don't have enough material or enough money to make a new shell i have had to make the most of it and bodge a fix which has resulted in an ill fitting rear panel and a bowed side panel. So lesson learned i believe.
Ah, that sucks! And completely understandable that it wouldn't have occurred to you, just one of those things. Hopefully you can restore it.
Not being funny, but, is there a chance you could put it back by the radiator in such a way it might return to original shape, or at least take some of the warp out?
I've heated it up with heat gun and have taken some of the warp out but only enough that it sort of fits together again, it's still strong enough i would have thought, i'll be retiring this chassis after the champs anyway so it only needs to hold up until then.
http://s921.photobucket.com/user/mrs...19795.mp4.html
Managed a quick video, just goes over the chassis warping in a bit more detail
