16.8v
Boring Brick
So i've put the packs on a discharge/recharge cycle and the one is fine, discharges and charges perfectly, the other pack has been on discharge for about half an hour now and has only had about 200ah taken out, it's not getting hot or anything but i think there's definitely a problem with it.
Are you sure you didn't some how plug one of the batteries in the wrong way? Eg. By plugging them into the removable link instead of battery connectors. It seems odd they would give off smoke if nothing has changed. Maybe a short circuit somehow across a dodgy soldering joint to the deans or exposed terminals?
Are you able to run it on just the one good battery?
Upon taking the robot apart i've discovered the true cause of the battery failure, my electronize are bolted to a plate of polycarb above the batteries and one of the bolts had pierced the battery casing and thus created a short and smoke. i've ground down the bolts now and taped over them so it doesn't happen again.
Cheers Matt but right now there isn't much point as i doubt i'll even be able to make it now. My idea of stuffing the bot into my toolbox seemed a great idea at the time but now it doesn't fit, and i doubt i can just plonk it on top and get away with it on a train, obviously i could take the axe off but that would mean gutting the whole robot everytime i want to get it to and from the event, so short of somebody giving me a lift up there which at this short notice i doubt will happen it looks like i won't be attending.
Need some help do ya
, having never taken a robot on a train before (obviously) it's hard to say how they would react, everything has sharp edge protection that needs to and the axe has a locking bar to stop it moving over, and obviously there aren't any batteries in there because well mine are toast. Anybody had any experience with trains and robots?
