As i seem to be stripping bolt heads faster than i can put them in i've had to hastily order some m6 high tensiles (up from m5), the m6 bolts that i've tapped into the baseplate have given me no problems yet the m5 for the chassis strip so easily. Does anybody have any advice for removing the stripped m5s because they've stripped their heads still inside the chassis
Boring Brick
Got my axe motor from Dave Weston last night who was kind enough to drive down to Birmingham to drop it off, however since the motor had no sprocket attatched I was planning on using an 8 tooth one I had lying around but the bore isn't large enough and I don't really have the right tools to widen it let alone drill and tap the boss for a grub screw. This puts me in a predicament as I don't have enough money to spare to get one from technobots and im not paying nearly 8 pounds from eBay for a 9 tooth sprocket which would have originally been used. So I don't suppose anybody has a spare one they don't mind parting with? Or would be kind enough to modify the existing sprocket with an 8mm bore and tapped hole?.
Just a quick question before i go ordering the sprocket, if i drilled a hole straight through the boss of the existing sprocket and drilled a hole through the shaft of the motor and used say an m4 bolt to hold it all together would that work or would it just be a waste of time?
Sounds like you're describing a cotterpin system. It would work in theory, but I'd worry a 4mm hole through would weaken it a lot. A much smaller hole for a pin of some sort, perhaps. You may find you can't drill the scooter motor shaft easily anyway, I imagine it's a decent, possibly heat treated steel that regular small drill bits might struggle to go through. Getting a designed-for-scooter-motors sprocket may be the path of least resistance.
So after realising that i need a sprocket with a 'D' shaped hole and hastily cancelling my ebay order i'm back to square one, which at this point looks like i'll have to get ANOTHER custom job from technobots, only problem with that is that at this point my robot budget is blown for this month and although i do get paid 6 days before the champs it's going to be a very tight squeeze to get the axe running before, so my plan to have the axe fully tested and working weeks before has slightly backfired
Is this not an option? http://www.ebay.co.uk/itm/Electric-S...item27dfccef95
With a half-round needle file you could file out one of the flats in the bore to make it a D shape, or you can grind/file a second flat on the scooter motor shaft to make that fit the sprocket. Both will work.
Sam, is it the MY1016 scooter motor? If so, I've just taken delivery of a new one for Onyx that has the sprocket still attached. I don't use it (I weld a Technobots one on instead) so if it looks like it will fit, it's yours.
It has got 11 teeth though, not sure how that plays into your axe ratio. The scooter motor currently in Onyx also came with a sprocket that might have been 9-tooth (certainly was double-D). Can't remember if I held on to that one but I'll have a look tomorrow morning and let you know.
Here are a couple of pics of the 11-tooth sprocket:
