Lift the arm out the way around spinners?
Team Pasty Build Diary: Loki
I don't know what you mean Alex...
Although I'm pretty sure I just drove up into the disk rather than I tried to lift the air in front of Binky lol Pretty cool sparks though:
The rear wheels will have gears and then belt drive to the front wheels.Originally posted by Flag Captured View PostYou've got S900 drive on 4WD, is it belt-driven? I would assume so, but I thought I'd ask!
Ziggy's flipper arm recesses into the frame and after seeing it up close & personal a few years ago, I can vouch that its very effective. Its probably not a popular idea, but have you considered going 2 wheel drive and using the spare weight on the flipper & armour?
I have considered just going two wheel drive and it doesn't effect the overall design really, quite easily just left out. I'm open to any ideas at the moment to get it in weight and be as effective as possible.
Also Nick I've taken a few stills and GIFs from my fights at the champs:
Got you hooked :P
After advice on the motor mounts I've designed, bit restricted for space at the rear end so I've come up with this:
The top two bolts are m6 80mm, and the bottom is the 14mm aluminium wheel axle, bored 5mm into the 15mm HDPE side and held in place with m6 bolts (don't tell Ellis that I steal all his ideas). Worried it might be a bit vulnerable being attached to the sides?
Also the mount I've designed in 6mm 'Ecocast' aluminium. Overkill? Adequate?
Cheers
