I think also if you dump, from your pressure release valve from were its mounted you'll fire the ram
Team Pasty Build Diary: Loki
I see what you're saying but going full pressure will cost me money I don't have at the moment and I want to build something now. When I do have money it will be for upgrading Loki 2. Also more flips on low pressure and fittings are cheaper/more available. Also the dump valve is on the buffer tank, plan to put a push fit adapter in it and pipe it to the rear:
How do I go about putting in an uptube/antisiphon tube? Tap a thread in the bottom of the pin valve, adapter and tubing?
Your dump valve is in the perfect place, so it won't open the valve when its dumped. From my memory of your thread I reckon you have everything for full pressure. As for an anti syphon tube.
check out the link of info
http://www.ebay.co.uk/itm/Paintball-...-/380285652972
