The bulkheads are 16mm thick Alumec - it's similar to 7075 in most respects. I'm using this because it was available, otherwise 7075 or 2014 would have been used. The other ali parts are from thicker billets of the same material.
FW Electric hammer - Robo Challenge (no name yet)
No problem at all! The whole point of a build thread is to show others how we do things and pass on info or learn things ourself!
But yes, my preferred choice for bulkheads would be these materials as the tensile strength is close to that of steel, but with very little weight difference compared to other aluminiums. That means certain sections can be thinner and held a lot of force.
The other difference is that they are very hard in comparison to the 6000 series, they don't bend so much as snap, not good for armour or plates that need bending. Also, machining these materials is soooo much easier as they chip off nicely and don't clog up the cutters like softer aluminiums do. Makes things a lot easier.
I did a little more work last night, but it's still going a little slowly as I only have a few more days left to get the most of it done!
I lightened out the the main gear on the first stage on the mill. Just need to make the shaft for this one now and get it keywayed on.
The gear cover is now machined and fits nice too
I start machining the cams tomorrow now as I was abit tied up today.
Dave, here's a link to the A28-150
http://www.robotmarketplace.com/products/0-A28-150.html
Sorry for the thread hijack.
Thanks! Do appreciate the help, I'm definitely no engineer so it's a lot to figure out otherwise haha!Originally posted by grant_ploughbot View PostNo problem at all! The whole point of a build thread is to show others how we do things and pass on info or learn things ourself!
It definitely sounds like those are the ideal for bulkheads then, best of both worlds! Going to have a look at getting some of that in then and machined into some decent bulkheads for HardWired when I can. Definitely a lot better than the 3mm aluminium I'm using at the minute, I'll say that much!
