think of a magnet on a fridge... easy to slide along but hard to pull off... the metal on metal contact is enough for forward momentum, putting rubber on it would just put huge strain on the motors during turning. Cad looks good btw Grant, see you tonight.
FW Electric hammer - Robo Challenge (no name yet)
Featherweights can often lift the side of a heavyweight up. I would expect that the flipper going underneath my robot would prize the magnets away from the floor slightly causing most of the downforce to go, and then be able to flip it fine. I'm not too sure until we try it though!
I hope to start machining it today/tomorrow
got soooo much to do in less than 2 weeks.
I think this should be an interesting robot to build, and follows the path of making featherweight versions of heavyweight icons.
the only difference this version is based on a heavyweight that didn't work properly. NOT JOHN'S FAULT I hasten to add.
The only disadvantage, this robot could only work properly on the Robo Challenge arena, as it is the only steel floored arena in the UK. I don't know are the floor panels bolted down enough? or the floor superstructure strong enough not to warp?
I hope to have a new Seraph robot for the UK champs too, that will be a sword or hammer. The difference is the ground clearance on it will be about 120mm and not less than 1.2mm
Good luck with the build Grant looking forward to fighting it soon.
Beta has sadly never fought in battle so It's quite difficult to know how effective it is. I'm sure it would be pretty awesome though! John was told the floor was a set thickness of steel and it turn out it was much thinner in layers and so the magnets just pulled the floor fight up and stuck it so it couldn't drive!
When I started the design on this one I wanted an electric hammer and started working on designs completely different to Beta as I don't want to make a copy of another robot. I was almost set on a flywheel design using a brushless motor to spin a flywheel and a Y shaped axe shaft with hydraulic caliper's built in to clamp onto the flywheel to work as a clutch. After working things out weight wise it still appears that the cam system that Beta uses is still the best option. Funnily enough Mortis uses a very similar system effectively.
I've made a number of alterations to try and improve the design over whats currently been done, such as having a much larger change in gear ratio (varies from around 22:1 down to 5:1) to give the mag a much easier time starting up. I've also made the ae arm longer, and the swing angle far higher so that I can put more energy overall into the weapon and make use of that larger change in ratios. It means I need to go with a short and stubby hammer head to get the extra movement, but I like the way it looks.
I''ve been trying to make it as far from Beta as I can, however the facts are that the way John designed beta is the best way to do an electric axe! This is the prototype version for my brushless one, using a system of clutches for rapid direction changing etc - but that's going to take abit of work!
Sometimes though it's difficult to deviate from the norm and be effective - in much the same way that many robots copied the general style of Chaos 2 because that was the most effective way to do a back-hinged flipper! Still, this looks like it'll be a beast of a machine once it's all finished! So many featherweights now that I really would not like to fight!
Does it actually rely on the magnets to run, or is that just for stability?
When running at full power it looks like it will need about 90kg of downforce to stop it jumping off the floor. If it does jump you loose all the effective power which would be ashame. I'll test running it on 6s with no magnets and a longer tail for events without a steel floor though and see if it can still be powerful enough for what Id like
I've spent a couple of day's working on the machine now since the gears arrived from HPC. I had a last minute change of mind and increased the MOD of the gears to 1.5 on the first stage and MOD 2 on the second as opposed to Mod 1 and 1.5 respectively. Looking at them now I think it was a good idea!
The bulkheads were just a fraction too large to fit on my mill, so Kane and Ant were able to machine these out for me from the CAD files I sent over. They've done a great job.
As you can see above the main gears are mostly machined out and have keyway's in. There's some lightening holes to put on them still but that will be done tonight. Test fit of the weapon motor, gears and prototype cam's all seem a good fit.
I'm now machining the gear cover that holds the bearing for the shaft on the first stage of gearing.
Just completed the back face here.
More to update on tomorrow
