The whole chassis is 46KG so not quite a tonne, its only 60cm long 36.5cm wide overall body is 10cm thick
Although its not very pleasing to the eye, it's been designed by the numbers. Lots of calculations for mass, density and so on have been done to find balance points, centre of gravity, deflection angles etc
We are using the hub wheels as before, but slightly differently you'll see in a few weeks
