Tanto 2013
  • Tanto 2013
    Re: Tanto 2013
    that's looking fit, what's it gonna be like finished (shapewise?)
      Re: Tanto 2013
      like this with wheels, its a monoque chassis
        Re: Tanto 2013
        oh cool so did you cut it all out of plate steel and then weld it all together?
          Re: Tanto 2013
          I believe all material you see is hardox.
          Yes, those forks are 80mm of solid hardox 500.
            Re: Tanto 2013
            thats awesome
              Re: Tanto 2013
              Solid hardox wedges! it must weigh a ton ! :shock:
              Looks pretty indestructible
                Re: Tanto 2013
                Are you going with planetary gearboxes built into the hubs of the wheels like some of the earlier versions of Tanto had?
                  Re: Tanto 2013
                  Someone missing bits off their forklift
                  Going to watch this with interest
                    Re: Tanto 2013
                    The whole chassis is 46KG so not quite a tonne, its only 60cm long 36.5cm wide overall body is 10cm thick
                    Although its not very pleasing to the eye, it's been designed by the numbers. Lots of calculations for mass, density and so on have been done to find balance points, centre of gravity, deflection angles etc
                    We are using the hub wheels as before, but slightly differently you'll see in a few weeks
                    finished version should look similar to this
                      Re: Tanto 2013
                      Very nice indeed
                        Re: Tanto 2013
                        drive is here
                          Re: Tanto 2013
                          Nice motors
                          What controller are you going for?
                            Re: Tanto 2013
                              Re: Tanto 2013
                              I don't really see a way of hurting that lol.
