Hi Dave
The answer is yes, the stress on the transmission is excessive, using an axle Bot is driving like you want to break the transmission, as if your life depends on it!!
The hubs have to be over engineered, the transmission through the speed controller and batteries have to be over spec just to survive. everything has to be securely mounted or padded out and damped down to stop the robot from shaking to bits!
If the wheels are from a mobility scooter then I would probably protect them as much as possible.
 Do you use live axles on your thwack robots or dead axles?
