Re: Tormenta 2 - Build Diary
Ours have never come with two plates... that's odd. We once put two in accidentally (don't ask) and it didn't like it at all, but I'll look into that tomorrow. Thanks.
I think it's simply the mechanical limit of a pin pushed into a hole, then loads of lateral force being put on it. If over the past 3 years it has been used and used and used, every time the drill changes direction hard the pins come under stress. So if we're lucky this is simply fatigue and we won't see a repeat with the newer gearboxes.
Also, oddly, one of the pinions on the 18v motors has come loose. Ewan has very kindly sent out a replacement, and we'll try to get the current one back together. I don't really have an explanation as to why it came loose, Ewan said he has never had a report of one loosening before, so I can only assume it was a dodgy one from purchase. Bit of a shame, as if we can't fix it we can't have any more test drives until we get to the UK and put in the new one, but it could be worse.
