Re: TXR - FLOW
As everyone has said fatigue plays the biggest part here. Regretfully once a robot has been in combat the fatigue has started. There are 2 options to try and cover this situation. Add a rule that ALL pneumatic robots have to be tested and signed off every year (This is practically what we do with spinners during tech check in the arena) or ban ALL systems being pressured whilst not in the arena barring CO2 bottles. Once the robot is in the arena you could then attach your bottle.
The only risk to people is when the robot is around people. Once its in the arena it doesn't matter to us if the ram blows or the rod shoots out. The arena is designed to contain it. If you would be worried about your pneumatic system failing inside the arena then the rules or the arena in question need to be assessed.
If something needs changing I would suggest it be allowing pressure into your robot whilst in the pits area.
Really nice build there Tom! very impressive.
