I was just raising a point. I was unaware they were ignoring the rules. Last thing I want is for you to get disqualified for it, that's all. Thinking of you Alex
Team Eventorizon: Build Diary
I have put as much electrical tape as I can on the cable. Yes, I aught to use grommets but you have to buy them in box's of 500 off RS and the tape worked well last time.Originally posted by Mouldy View PostYou bought a 3d printer then? I was more concerned that you had each wire for the link passing through a seperate drilled hole in the lid with no grommets etc
And no worries Dave, I know you meant well. That said I can't get an LED on the weapon side of the power system cos everything I have put in there has been cooked by the high voltage so I hope Binky wont get failed for that. Drive has an LED though so hopefully that is enough.
Excellently! Great profile, stupidly lightweight, more compact and much stronger that I expected. I am hoping to give C3 its first drive today so I will let everyone know how they cope.Originally posted by harry hills View PostAlex, didn't you print your own timing pulleys? How did that go?
Thanks Alan! I will see what they have.Originally posted by blazerbotics View PostMaplin do grommets in packs of 10. I would say you need an LED on the weapon side as well if they're 2 independent systems.
As for the LED on the weapon side, How do other people add an LED to a 42V system. Conker 3 will be even higher at 50.4V! Every resistor I have tried has burn out either immediately or after a couple of minutes.
[/QUOTE] Thirdly, as beetles are definitely on the up I have concepted not only a few beetle machines but a beetle arena...
The arena is around 400kg when built and is 2m x 2m x 1m with 10mm Polycarbonate on every side and a 4mm thick steel floor. Finally there is a 200mm tall 4mm thick kickboard round the edge and a door at either side of the arena. The arena would actually serve as both a Beetle arena but also as a featherweight testing and demonstration area. In the same way you can demo/test a single heavyweight in the RoboChallange arena you could demo/test a single feather in the Beetle arena. There are currently no rules about this and I feel that it is something that aught to be talked about and decided upole.[/QUOTE]
Sorry to go off topic slightly but why are all the beetle arenas pitless and have no out zones like over an arena wall like current arenas? It would make winning with my beetle flipper near impossible as ill just be flipping stuff for the fun of it whilst a spinners free to rip it up, thoughts?
I use a regulator like this to run a LED off a high voltage pack: http://uk.rs-online.com/web/p/switch...ators/7398297/. Just add a small dropping resistor and maybe a capacitor on the output side. I think Recom makes a 1/2 amp regulator in a smaller pack.
Looks like that will work for Binky, since she max's at 42V. C3 may need a 2 stage reduction to get to the necessary 12V: One regulator then a resistor.Originally posted by overkill View PostI use a regulator like this to run a LED off a high voltage pack: http://uk.rs-online.com/web/p/switch...ators/7398297/. Just add a small dropping resistor and maybe a capacitor on the output side. I think Recom makes a 1/2 amp regulator in a smaller pack.
Ok, the current solution is this...
One of these in each robot so I have a 15V output from the weapon system...
http://uk.rs-online.com/web/p/switch...ators/0416846/
...then an in-line resistor to bring the voltage down to 12V.
Since I need 260mA of power to drive the LED's in Conker 3 I need a 12Ohm 2W resistor (15V Source Voltage, 12V LED Drop and 260mA current required to power all the LED's).
In Binky I will need 120mA of power so I will need a 27ohm 1W resistor (15V Source Voltage, 12V LED Drop and 120mA current required to power all the LED's)
Can anyone see an issue with that plan?
I found themOriginally posted by overkill View PostOver 42 volts? Why not go straight to a Mr Fusion battery!
. Recom do another series up to 72V; search for R-78HB3.3-0.5
Thanks for the heads up. Its much easier to do these things when you know what is out there.
EDIT: Typical... they are out of stock
