Re: Rukia (FW)
Try recalibrating the XL. I've found in the past that if I calibrate it with all the servo leads plugged in, and then take one out later on, it doesn't behave entirely like it should. So make sure all the servo leads that you are wanting to use are plugged into your receiver, then recalibrate the XL. It may or may not solve the problem, just an idea.
The only other thing I could suggest is that if there is some sort of failsafe setting built in to your tx/rx then it could be wrestling with the XL failsafes, but having not used a DX5e or AR600 I don't know if that's the case.
