Re: Spiderbot
Hi Alan
I like the walking action of this type of robot too it dose look like a spider.
It's not as efficient as the pilgrim design, as the robot tends to bounce up and down as it walks (this uses a lot of the available energy and why I'm trying to loose weight). with the pilgrim design this problem is reduced to a minimum.
Also with the sets of legs so close together they tend to get tangled when you turn. one reason Pilgrim has the legs equidistant.
Hi Archie
With regard to the Sidewinder this came with the robot so I am putting it in to start with. the motors are only 240w 24v, so a Sidewinder is a little over kill.
In Pilgrim I used the Dimension Sabertooth 2X25 with the same setup and the controller never even gets warm. I may go with a small Wotty 100 I have and see how that dose in the robot.
I did get the robot moving yestarday but only on 12v.
Hi Alan
Hi Archie
