Ok,
Laser 2 atm won't work, so it needs alot of changing.
The sabertooth 2x25 is almost dead now. we have been having problems with it since we went to 4wd, at Worthing we blew one side of it and the other works when it wants. So it needs changing.
We're going to change it to a scorpion xxl v.2 with a fan and enclousure.
The lifter mech is'nt up to the job. It broke twice at worthing the second time just messing around(thanks Haz
). The bearing mounted at the front broke after being flipped by whirlwind and landing on the fipper. So we need to make a sufficent mounting.
The other problem is that we were grinding the thread down on the m8 threaded rod untill when I tried to lift Murphys law I stripped the thread in one part and bent the rod. So we need to get a car jack and take it appart.
We are also going to make a circuit so that the lifter will have limit switches and wont destroy itself.
sorry about that mate
