Back in the day, we had eight local events a year and one or two larger interstate events. Nowadays, we are down to just one or two events each year
scruffy
Haha, going to Belgium for an event would be a disaster for me - too much much delicious beer to distract me! The problem with Australia is that its so large, under-populated and isolated. To get to our national event, I do a 2,000 km / 24 hour drive over a long weekend - not something you'd want to do that often.
ok started building some more BW so far im making a BW version of night fury fairly similar construction to glitch but will have 5mm aluminium armour
i was planning a 6wd with 3mm thick tool steel armour but as there is already a 6wd im now going for tracks using 4 motors to drive it
i havent really done much to scruffy 3 and im still toying with 2 ideas for night fury 2, just cant decide to stick with the original design but in thick hdpe of to make it more like like scruffy 2 with sloped sides 5mm steel and a few well placed reinforcements
I reckon that Newton could have a good go at it. It cut through the 3mm mild steel wall on a ricochet so if its actively aiming to cut this I bet it will go though if it catches it right.
Susan should also be able to put some slots in it once she is built. Just the sheer power to weight ratio of spinners makes even the best feather armour vulnerable.
Hardox weapons regularly break or twist Tool steel ones. I don't think any one has ever used Tool steel as armour over here though so we will have to see.Originally posted by Liftoff View PostI doubt a spinner could cut through any type of tool steel, specialy the tempered ones. Its much tougher than hardox or titanium but heavier than both. I would be concerned about shattering tho, mounting your tool steel on aluminium might help.
ive used this setup before and never had a problem with the motor/gearboxes, one of mine had 2 years worth of abuse with no maintenance, i finally checked over the internals as the chassis was knackered..... bent and twisted thanks to 720 and conker and all i had to do was tighten the screws holding the motors on
