Full Tilt
    Re: Full Tilt
    planned completion date summer 2012.... then thats another £50 you owe me swanny !!
      Re: Full Tilt
      They are just a few bits I know....Pictures really to show off the lambert Powerdrive. I know its a long shot but hopefully maidstone. if its not ready for them i shall bring along what i have done.
        Re: Full Tilt
        so thats why you bought an etek off me
          Re: Full Tilt
          Secret out.....Actually the Etek i bought from you was for the job but was just too big. Will use a mag motor to start with and upgrade later if we think we need it. Mr Hoppitt recons the mag will be more than powerful enough...it might be but will see.
            Re: Full Tilt
            there is no such thing as having too much power Swanny! if you can fit the Etek in, then do it
            I finished Scrap Dog and I'm using my last Etek to make a hammer bot once I finish Tanto, Etek's may be old tech but they have plenty of power
              Re: Full Tilt
              That reminds me, Craig, do you have any pics of scrap dog?
              Also, just looking at the CAD pictures, how are you gonna keep both halves level, Swanny? Surely one will move but the other will stay put?
                Re: Full Tilt
                Big Nipper only uses a CIM2 motor, all depends on the gearing.
                • #23
                  Re: Full Tilt
                  Yes I do thanks
                  • #24
                    Re: Full Tilt
                    Are they a secret?
                    • #25
                      Re: Full Tilt
                      is it a heavyweight of scrap mamba? :P
                      • #26
                        Re: Full Tilt
                        That would be cool
                        • #27
                          Re: Full Tilt
                          Jarvis....the weapon will be mounted on 2 bearings that are mounted onto a solid bar that will go right through the robot and into flanges on the outer chassis where they will be keyed and grubscrewed. the same on the inner side of the chassis.....about 8 inches of keyed bar in total....flanges will be welded to chassis. I hope that will be enough to stop the twist you suggest but in all honesty i dont know how it will perform as its not been done before. The bar is hollow 50mm OD with 15mm wall. If it fails i will just redo it stronger.
                          • #28
                            Re: Full Tilt
                            I have considered at length a heavyweight version of scrap mamba but its already been done....
                            http://www.vantec.com/marksetrakian_sna ... _small.jpg
                            Scrap Dog is a simple wedge bot made of complete crap I mean scrap parts meant to be similar to Wild thing
                            • #29
                              Re: Full Tilt
                              is that snake from battlebots?
                              • #30
                                Re: Full Tilt
                                Craig the picture reminds me
                                I have been trying to think of a neck and tail mechanism for Pilgrim I have decided I might make it into a Dinosaur type creature A safe Plant type nothing aggressive
