around the 4000 rpm mark. The reason for the low KE is the relatively small diameter of the drum. If I took the same 4kg and increased the diameter then I could in theory store more energy in the disc than typhoon 2 however the resultant disc would fail on impact from lack of structure.
Did a bit more work today, I wired and fixed in my led and put in some 25 amp fuses from tecnobots to protect my esc. Tried to screw it onto the base plate but my countersink sucks so the screw heads scape along the floor so need to get a new decent countersink tomorrow hopefully! I can't weigh it to see how it's doing because last time I tried I broke my mums bathroom scales so I no longer have any, what type do most people use to weigh featherweights?
Also what receiver should I use with the spectrum dx6i transmitter, I know it should failsafe on all channels but I don't know which receiver does that?
The BR6000 (not 600, just to save confusion) I believe will work on transmitters DSM and DSM2, but they are not made anymore so better going with one of the other suggestions.
