team combat penguin build diarys
  • Re: team combat penguin build diarys
    Laser by far
      ahem
        Missing a couple of wheels there if you want to stake your claim Harry :P
        EDIT: Besides, Kaizer's the best. Okay so I don't own it now, but allegiances still lie
          I think ill change mine to three wheeled drive now
            harry: ahem ahem
            jamie: kaizer falls apart too often to be crowned king lifter
              Not once I'm finished with it
                What you doing with the current ML then? Keep running it?
                  nope.
                    Converted one of mine to three wheels, not as easy as it seems!
                    May need to crack out some omni-wheels.
                      Bah my FW is also going to be a 4wd drill motor lifter, scary similar to laser and kaizer :/
                      Maybe i should add some fur to make it stand out? :P
                        make it triangular
                          Falls apart. Cheeky beggar. It's only the front panels. It took LS3 to get anything else off.
                          Kaizer did fall into disrepair though. I was distracted building a pneumatic flipper so it got worse & worse. Didn't help that the lack of end switches was slowly destroying the lifter everytime I switched the machine on.
                          Still Dave's got it atm & is removing the weaknesses. He's started well by removing me. lol.
                            since this forum is far too boring, thought i would share what i have been doing (with Jonny) for the last few days
                            http://www.youtube.com/watch?v=Ejnpe5YIezA
                              18V was scary!
                              If you do decide to go brushless, just go for one motor. 360 ran two brushless motors originally but changed to one slightly larger one (can't remember the exact reasons why) but the weapon appears to have been more reliable since then. Plus you've got double the costs with two motors and two ESCs.
                                gave it another spin up on a fully charged 12v battery, was much better. span up in a couple of seconds and no smoke this time
