Re: Cicatrix Build Diary
The weight loss has just been a result of the design. The new drum is shorter, has less teeth and has lighter end-caps whereas the old drum was longer, had four teeth (each being 15mm thick instead of 13mm) and stainless steel endcaps. Not sure what the density of Supralsim 690 is (new drum teeth) compared with Hardox 450 (old drum teeth) but there could be some weight difference there too.
Yeah ideally as much weight in the weapon as possible. The whole robot currently only weighs 11kg I think, so the weight is there to use. Contemplating a beater replacement, making it thick and throwing as much weight as possible into the outer edges.
