Re: Team Jamsandwich Build Diary
on the bearing front im not to sure but as its the weapon id say using the bulkheads or what ever and a pin should be fine
depends what your drilling in and into what???
for example a screw into wood can often be put in with no hole
but going into metal your best off to use bolts an 'tap' the hole before which first needs to be drilled.
