Re: Hard Time's build diary
Don't forget to have the jigsaw running at a low speed. This will reduce (although not eradicate) heat generated during the cutting process. I find a coarse blade (bigger teeth) to be best, as has been mentioned. Don't force the jigsaw through the material, just take it at a steady pace and it will be fine. It should fly through 6mm HDPE and will also be pretty quick through the 15mm stuff.
I wouldn't bother too much with coolant for it; if you keep the speed down (maybe setting number 3, if your jigsaw goes from 1 to 6) and take it steady it will cut without issue.
