Hard Time's build diary
    Re: Hard Time's build diary
    Don't forget to have the jigsaw running at a low speed. This will reduce (although not eradicate) heat generated during the cutting process. I find a coarse blade (bigger teeth) to be best, as has been mentioned. Don't force the jigsaw through the material, just take it at a steady pace and it will be fine. It should fly through 6mm HDPE and will also be pretty quick through the 15mm stuff.
    I wouldn't bother too much with coolant for it; if you keep the speed down (maybe setting number 3, if your jigsaw goes from 1 to 6) and take it steady it will cut without issue.
      got a bench saw and cut the Hdpe today tomorow cutting the top and bottom and uploading pics of what my robot will look like.
        cool
          Yeah it's gonna beat yours!!! Havent cut the rest of plastic yet because a)I've had loads of homework b)becaus eI have to use the bench saw outside and because of rain I cant (humph(angry)). Hopefully getting the plastic cut soon.
            mine will easly beat yours, for a start my robot has 2x the amout of pushing power, thicker armour and a better driver. lol
              Ok lads. coold down, save the aggresion for the arena :twisted:
                lol
                • #23
                  Got a bench saw a few days ago... Tested wood on it and it cut fine blah blah blah.
                  Made the outer frame cutting the base and few little twiddly bits got some screws.
                  • #24
                    sounds good
                    • #25
                      forgot to add I mucked up the back of the robot; once I had finished cutting I stupidly left the saw still spinning and I pulled one end of the plastic away pushing the other end into the spinning sawblade so there is a big curve one end.
                      • #26
                        ha, lol.
                        did you have enough plastic to rebuild it
                        • #27
                          I dont have any left over, but luckily I'm cutting the bad end off because it is too big.
                          • #28
                            Cut the plastic last night, trimming it down to size today.
                            • #29
                              Made a jig to make it all to size uploading pics of what it looks like so far.
                              Ordered 4 100mm blue wheels, hopefully coming today.Where is the best placed to get shafts and bearings?
                              • #30
                                presumably your getting the blue wheels with nut insert in???
                                what motors are you using??
