Robo Challenge - Predator
  • Re: Robo Challenge - Predator
    Both gears modified, one ready to weld onto the thread and the second gear has been machined out to fit onto the servo horn.
      Well all is complete! the head tilt mech is finished and in the machine. Its extremely tightly packed. Need to find a new home for the scorpion esc now. Head is almost full retracted here.
        And here is the head fully forward, you can see most of the head tilting mech here.
        Next job is the arms mech and creating the single tooth for the head. Then its armour up time and away we go!
          the picture mentioned doesnt seem to be there??
          all looking great nice work
            Here we go, thank you very much.
              very cool
                looks brilliant, is the tilt mechanism like an actuator?
                  Oh I see what you're doing! You've a gear on the servo head, which engages a gear on the threaded rod. The thread on the rod then pulls and pushes a nut which is attached to the head?
                  Does the servo have enough travel?
                    Yes your right PJ, I've modified the servo so it continuously rotates. It has 14kg or torque and rotates once in 1.08 seconds so it's slow but that means we can keep it very controlled.
                      Neat idea! How are you limiting travel? The idea of using switches seems too flimsy in a combat robot.
                        cheers PJ
                        We will be using our eyes and control finger instead of limit switches
                        there will be physical stops on either end too.
                          Been working on the arm mechanism this last week. All the bit have arrived including my nice little ball screw
                          I really wanted to work the arms off a drill motor as they are nice and easy to replace and can be put under good strain with out burning out when used at the normal voltage. Only snag was its too big to fit in the robot so I set about making the gearbox smaller.
                            Machined out gearbox is as short as I could make it. finger crossed it fits!
                              Machining out the drive gear for the motor side
                                Hey presto! finished motor mount/gearbox with modified shaft and arms drive gear.
