Re: The latest machine from Robo Challenge
Got a bar of 12mm silver steel. Truned both ends down to 8mm with a 11.5mm wide section in the middle at 12mm diameter. Then i put it in the milling machine and faced off 1.5mm off the 12mm diameter section on all four sides to give me a nice 9mm square with radius corners. I then used a 3mm cutter to mill out the squares in the gears.
