elobire's build thread
    Re: elobire's build thread
    whats a pidgeon?
    also how do i connect the motor for my axe to the reciever, will i need another speed controller?
      You will need some form of interface to allow the receiver to control it. Either a speed controller however I'd be more inclined to use a big relay activated by a remote controlled relay (dimension engineering battleswitch or similar controlling an automotive relay or bigger).
      Others have wired up relay based axe systems in the past so they will be able to advise you on a suitable diagram (can't think of it off the top of my head atm)
        is their anyone here who can draw me a quick diagram for it please?
          Originally posted by elobire
          whats a pidgeon?
          lol, a pidgeon is a bird
          *what it actualy means in robot terms is a weld that looks slightly ugly/messy, but tbh as long as it holds the metal together its all good *
            does anyone have any suggestions for the relay and battleswitch?
              just ordered the chain and sprocket as well as 2 flange bearings. just need the motor, battery and transmitter.
              still need to decide how im going to controll the axe.
              EDIT: do you guys think this battleswitch will work for the axe?
              http://www.robotmarketplace.com/product ... TLSW1.html
                when people say battle switch they mean the one you have linked to its a product brand if you like
                and yes thats right but you will find it on technobots btw
                • #23
                  oh i understand now.
                  just a bit miffed when i noticed the VAT on technobots for the battleswitch was 17.5%, i guess thats what we get for voting in cameron.
                  • #24
                    No, that's what we get for living in a country where VAT has been 17.5% for quite a few years now :P
                    Now that Cameron's in, it will be rising to 20% from 4th January 2011.
                    • #25
                      *wallet goes and hides in corner*
                      • #26
                        this ones cheaper...
                        http://web.me.com/robochallenge/Robo_Ch ... onics.html
                        and its english if thats ok
                        • #27
                          thanks for the link. il buy it from robochallenge, bought stuff from them before.
                          • #28
                            Just a word of advice; a battleswitch turns something on and off (in some cases, such as yours, through a bigger relay). So that means you can turn your axe motor on (fire forwards) and off. But you need to return the axe so you will need another battleswitch to turn the motor on in the other direction (axe return).
                            Based on Technobots prices, a battleswitch costs £19 inc tax, so for two that would be £38. But they also stock a Doubleswitch, which is a dual battleswitch for £25 inc tax, saving yourself £13:
                            http://www.technobotsonline.com/doubles ... ay-8a.html
                            It is a double-pole, double-throw switch, which is needed to control a motor in a fwd-off-back manner, so connecting this up to two larger relays should provide you with the ability to both fire and retract your axe.
                            • #29
                              thanks, do you have any recomendations for 2 larger relays?
                              • #30
                                Can do, although using large relays for weapon control is an area that I've not really had to delve into yet, so another forum member will probably be able to make a better recommendation as to which type to get.
                                In order to get an idea of what relay to use, can you provide a link to, or some information about, the motor you will be using for your axe?
